mRaaghava
- Sep 29, 2016
Which DAC among Gustard X26 Pro/R26 pair better with this amp and Arya Stealth?
I would go for Gustard R26 and alternative opamps. The DAC is apparently much better than the X26 but with the R2R warm sound, if you get a transparent sound from the Burson 3X GT with alternative opamps you will have one of the better setups possible for your headphone of choice.Which DAC among Gustard X26 Pro/R26 pair better with this amp and Arya Stealth?
Alternate opamps means a mix of vivids and classics right?I would go for Gustard R26 and alternative opamps. The DAC is apparently much better than the X26 but with the R2R warm sound, if you get a transparent sound from the Burson 3X GT with alternative opamps you will have one of the better setups possible for your headphone of choice.
Sparkos, SIL, Staccato etc.. see the previous posts in this threadAlternate opamps means a mix of vivids and classics right?
Okay, I've been playing mix-and-match all weekend between the following op amps:
- Stock red Burson
- JRC 5532D included in the amp box
- SIL 994
- Sparkos SS2590
- Burr Brown OPA2134PA
My absolute favorite combination is... stock red bursons on input and volume, and Sparkos SS2590 on voltage output
Funny how that works, I could have saved myself lots of money
Still interested in trying those Orange opamps though
Are you saying all 6?when you hear the Orange Op-amps, you will forget about the equipment and listen to music all day..
Also have you compared them to others?
So are you suggesting orange or alfa rppar? And all 6 of each or a mix?yes.
for volume i use -130 db op-amps from alfa rppar . it's a company from Latvia. I accidentally found them via a russian youtuber!
the bursons smear details... in comparison
I am trialing this config. So far outstanding and the most “tube-like” of anything I have tried. Need more time evaluating, but I really like what V6 Classics bring to the table. It’s the first config where I stop thinking…and just get lost in the music. I can also now explore more of the high gain setting now on the GT without it feeling like overkill. Man, this thing is fun to own.Final update on my op amp issues. Reached out to Burson audio support and they advised me to not use third party op amps as customers have reported back with burnt headphones or fried units. They don’t cover them through warranty and so only recommend I use their op amps in my unit. Unfortunate as heck, but I suppose I’m just unlucky that my volume stage won’t accept third party op amps. I’ll likely sell my 994s and stick with my 2590s as I prefer the sound with them in the input buffer stage. Might try out the v6 casuals since they should work in the volume stage.
Im surprised they would say something like that, unless my memory is wrong Im sure they used op amp swapping as a selling point. If that is the case, they need to offer more than 2 options of op amps considering people have seen pretty sizeable improvements swapping out the v6Final update on my op amp issues. Reached out to Burson audio support and they advised me to not use third party op amps as customers have reported back with burnt headphones or fried units. They don’t cover them through warranty and so only recommend I use their op amps in my unit. Unfortunate as heck, but I suppose I’m just unlucky that my volume stage won’t accept third party op amps. I’ll likely sell my 994s and stick with my 2590s as I prefer the sound with them in the input buffer stage. Might try out the v6 casuals since they should work in the volume stage.
Attaching my correspondence with Burson audio. Apparently others have complained about the Sparkos.Im surprised they would say something like that, unless my memory is wrong Im sure they used op amp swapping as a selling point. If that is the case, they need to offer more than 2 options of op amps considering people have seen pretty sizeable improvements swapping out the v6
