thecrow
- Oct 18, 2014
My thoughts:
1. You should try cleaning the contacts to stop the popping.
2. Use Caig De-Oxit. It is better than WD40 for this application.
3. DeOxit is designed to evaporate quickly and leave no residue that can attract more dirt. WD40 is designed to leave a lubricating residue.
4. DeOxit does come with a straw.
5. You might not need to take the attenuator out to clean it. Before taking it out you can try to clean it while it is still installed.
- Open top of amp.
- Spray DeOxit contact cleaner into the attenuator. I few quick blasts releases a lot of cleaner.
- Move volume control knob back and forth through the full range. Do this a few times as you are working the cleaner in between the contacts.
- Spray the attenuator with the DeOxit Gold and turn the knob through the entire range a few more times. The Gold will help stop dirt from accumulating.
- Give it an hour or so to dry. You can keep wiggling the knob as it dries.
6. If this doesn't work, you can remove the attenuator and clean more thoroughly.
the wd40 i was thinking of was "the specialist contact cleaner" which may be similar. But i assume you have had success with the deoxit gold so i take that on board
whats the likelihood of it working without removing the attenuator. would the pop only be coming from the centre or could it be elsewhere? i ask as i'm not sure how this all works or even why the pop exists - if you can shed some light on that that would be of interest too
thanks
