nwavesailor
- Nov 14, 2009
Were you using a DAP for amp before the FUN? Are you using the Aux input on the front panel of the FUN or RCA inputs on the back for audio in?
Very good!
I'm kind of looking for something different sound wise as well. I do like my current setup but at $200US (including V6 opamps) it seems like it's worth the gamble. Hard to say how the FUN will sound as a preamp with the V6 opamps as my tube amp is a hybrid and uses a pair of opamps as well.
Did you go for the Classic or Vivid V6's?
The amp may be 'cheap' but tube rolling can get expensive! Heck you could snag the P20 & go off the deep end (with me) and add the tube amp after the FUN as a preamp!
Not sure what are equivalents to the 6N6 stock tube for rolling but I'm sure you could buy some better tubes than the stock pair it ships with.
The 2C51 / 5670's are supposed to be a fantastic tube. I avoided going down that rabbit hole but a lot of Head-Fiers think they are great (and not too expensive) tubes.
Have you read the FUN review here on Head-Fi from 'Alcophone'? He raves about the Sparkos ss3601 opamps in the FUN.
I think I'm getting off the fence and placing my order with Parts Conexxion!!!
I had problems getting my FUN going again today. I kept unplugging and replugging. After a couple of minutes I got sound. Previous to that it was just lots of double clicking and occasional static. I guess it is a connector problem?
Sounds awesome once it starts working.
Shane D
Cool, let us know your thoughts about them. I’m interested in selling if they will bring up the detail level even more to match that of the Gilmore Lite MKIIOrdered with V6 Vivid opamps!
I got this on my PLAY V1.6, it was from the power plug. It's really easy to investigate: while powered ON, check if the power plug is plugged into the FUN perfectly (till the bottom of the plug), then try moving it a little bit left-right. If this will cause any power-related issues, then the plug it's too loose. If so, then try finding a good position for a better contact, maybe get the power cable from under the FUN to be more steady. Of course, if this is a re-ocsuring and annoying issue, you might want to contact Burson.
I have jiggled all the plugs and the only one that seems to have any effect is the headphone jack.
It was bad on Friday and better on Saturday. Today, I can't get it to work at all. I got 20 seconds of sound and then it cut out. Very frustrating. I LOVE the amp, when it's working.
I am going to ask the dealer for an RMA and hope he offers a replacement.
Too bad as I was really enjoying it. I had my headphones on for almost seven hours yesterday. It is a perfect match for my Grado's. I was hoping to try out the T5p.2's today.
Shane D
What made you choose the Vivid's? Based on a lot of reviews and Burson's advice I got the Classic's. My dealer had actually recommended the Vivid's. I figured I would just buy them later separately.
Hope your amp works perfect out of the box! They really are amazing. My Grado's had never sounded clearer or sharper.
Shane D
