i used eac for all audio writing, unless i use the combined read/write offset function so that i can burn with nero (with fully corrected offsets, even though nero doesn't support that) and use my burner's "audio quality" mode. generally, i burn at 16x (since that's my burner's highest speed for CAV writing) and for the audio quality mode i use the burner's auto-select speed setting for the media, but it generally ends up using 8x.
i don't burn anything at 1x or 2x because my first burner was 2x and i've spent way more than enough time in my life waiting for cds to finish burning and there's no way in hell i'm going back to it when my burner is capable of finishing a cd in under two minutes. it's silly, it's stupid.
i think that article is a little nutso. i really find it amusing that this guy is doing all this comparing and isolating his burner and all that, and he's using the ****tiest software on the market to rip/burn his examples with. use eac and read about setting correct offsets here:
http://www.ping.be/satcp/eacoffsets00.htm#- and THEN tell me if you can hear a difference in media/burners, maybe then i'll believe you.
i guess i should spend a bunch of time and blanks writing a bunch of test cdrs so that i can see if this crap is true or not, but i'd really rather just sit down and listen to the original cd instead. oh well. i'll stick with my current burning strategy, especially since the burns go in my car and its stock system isn't worth tweaking the cd for anyway.
for the record i think the black media is pretty cool, but i don't really use it very often. i buy either imation, tdk, fuji, or memorex.. whatever is on sale at best buy in 50-packs. in my experience, as long as you stick to the bigger companies you're okay. i'd stay away from that "too good to be true" priced media, as i've had bad experience with it in general.
