Originally Posted by haloxt /img/forum/go_quote.gif
What you think burn-in is contradicts what chinesewiki's links suggest. I was wondering if you had anything to say about that.
I've seen these links before and am a long time member of HA.
Where does it contadict what I said exactly?
There's no evidence in a test with such poor resolution to suggest that the first few movements of the speakers result in the most burn-in. I probably worded the "first few minutes" remark poorly, as I was referring to per flex of the diaphragm, not the absolute threshold of burn-in occurs in the fews few minutes (although a lot of companies actually burn-in their drivers before they ship them, so it wouldn't surprise me if a few minutes was indeed the case for these manufacturers).
I also believe that these speakers were burnt in using low frequency test tones (15 and 20hz I believe are quoted), which whilst they will produce large movement of the speaker, I am not sure they will be as effective as music (as the motions are slow and large, rather than fast and large). But I dunno, there's no scientific evidence I've seen that suggests the "most effective method of burnin"
There are also various anomalies that suggest the test was not completely accurate,
R1 for example does not follow a pattern in one direction. But I don't care too much about that.
I'd go and attempt to force the data (which is insufficient) onto a logarithmic graph just to appease myself, but frankly I don't give a damn about burn-in, despite my belief in it. I'm too busy listening to music. I'd like you to provide proof that you have indeed verified that the burn-in process is not logarithmic (you can use that data if you like) before you "call me out" on something from a single source with poor resolution.
This is not the sound science forum. This is a headphone forum that people use to decide what headphones to buy, or discuss headphones that they use to listen to music. Burn-in has no place on this forum IMHO other than a quick mention that some people like to do it (I believe there is a sticky about it).
Let's not even get into the difference in surface area, and the volume of air being moved.
How 'burnt-in' do you think the topic of burn-in is, anyway?
