John Reeves
- Apr 4, 2004
Hi,
I have built and changed components etc on an HTPC for several years. I have now reached the stage were liquid cooling is the only thing I haven't carried out.
If you are running Windows XP it is pointless to install more than 2gb of RAM since the software has a RAM limitation.
I use a Silverstone desktop case an Athlon CPU since it runs cooler than the Intel equivalent, a passive cooled 9600GT (I play back videos etc), a couple of SATA disks (I have found from experience that Western Digital make the most reliable drives, never had one fail and they are also quiet).
I use a quiet power supply, larger cooling fans than the original ones - this quietens the unit since they are running at a much lower speed.
Obviously a quiet CPU cooling fan is desirable to cut down noise.
I use a Juli@ soundcard fed to a Benchmark DAC then into a Linn Naim system. (This is currently being updated). The DAC headphone output is excellent.
The other thing no-one has mentioned is the front end - have a look at Media Portal:
MEDIAPORTAL - free MediaCenter HTPC Software - MediaPortal Downloads
If you wish then the alternatives are Winamp (Get an early version, the latest are bloatware), or Foobar.
These are all free.
The best video and DVD playback software is Theatertek IMHO.
Obviously use ASIO and FLAC so be sure to get a sound card that supports ASIO.
RME are excellent in this respect since they have their own ASIO driver.
You can get cases with built in remote sensors and controller software, but I prefer to use a wireless keyboarI hope this helps.
Regards
John
I hope this helps
These are all free.
Regards
John
I hope this helps
