thelostMIDrange
- Nov 1, 2011
so you have the stock plastic inners with cosmetic outer sounds like. keep it, Ill get the my buddy to mill up a sweet set of inners. you will then stick them inside your coco outers. the mags get mounted in the inners, you use your stock headband and it's done. my tale is a long one but alot of that music you seem to be into is very well recorded. And I mean that. that stuff shines on the kind of wood my buddy would supply you with. it's all midrange attitude. order your drivers.
