ok computer
- Mar 24, 2008
Ok, let me start off by saying that I'm 14 years old and don't have much experience with high end audio. I could be called an audiophile in training, but I just really love music. I will be building a new system over the summer for listening in my room with my hand-me-down laptop. I would like to spend as little as possible, but will probably have around 1000$ max. Portablility is not a big concern but It certainly doesn't hurt either. I don't have any place where I can go and try out high end headphones, but I do have some er6i's which I like and had some hd-25-1 IIs which I just sold If that tells you anything. The 1000$ will be for everything, headphones, amp, dac, IC's, and power cables?. I listen to a wide range of music so instead of telling you what I listen to I tell you what I don't listen to. I don't listen to anything on mtv, country, metal, hard rock, screamo, hardcore, emo, or punk.
Since I don't really know what brands I like I'll try and describe as best I can the sound I'm after. I want something with good sounstage and imaging. Something that sounds open and has good depth. I want an out of the head experience, so I can close my eyes and the headphones disapear. It needs to be a good all-rounder, not something that just sounds good with one genre. The whole system needs to have good synergy and take whats on the recording and reproduce it for what it is. I want something that is non fatiguing, that I can enjoy for hours, but still be deatailed and revealing.
I really hope that incoherent mess of a paragraph helps. Some of the gear I've been considering are hd580, cheap stax of some sort, ergo 2s, markl modded d5000, the keces dac's, little tube 3 and 4, and pico. I just want something that will provide my first eargasm, and countless hours of aural pleasure...............thanks!
**I value everyones opinion but I would appreciate feedback from more eperienced users, that have tried lots of gear, and different setups.**
