bangraman
- Oct 3, 2002
I've been playing with heatsinks, fans etc until I can hear them whirr in my sleep. Extensive work also with calculator means that I can tell you how much a quiet-ish PC costs without thinking. It is possible to get quiet, but not at the same cost / dimensions. Most of the cases / PSU combinations were a disaster. The Antec was one of the worst in the end, because it gives you so much hope when you turn it on. However after it's been on for half a day, the PSU is up to full operating temperature and it starts going like a jet engine. The fan moves little air so the in-case temp is very high... and all this with a 2.5" drive. I've swapped heatsinks in inaccessible places so often that I've already killed two processors through over-application of pressure when mounting / removing Cu coolers. I've got multiple cuts from heatsink fins and bad case finishing.
I'm giving up. For all sorts of reasons, IMHO the Mac Mini is king for audiocentric living room use as a low-cost, silent source (especially with an external USB interface), although good 'see it big' options are few. CenterStage is looking to become a good free option.
bangraman has left the thread
