Dreamslacker
- Oct 7, 2002
I think you need bigger heatsinks, use thermal compound instead of thermal pads (will explain this later) and use something to apply pressure.
Thermal phase-change pads require high temperatures to become effective. A constant 70'C across the pads for a couple of hours with pressure applied allows them to undergo phase change.
This will allow them to fill in the gaps between the heatsink and the device effectively. Without phase change, they'll not be as effective.
With a long (and tall) bar shaped heatsink you should be able to lay it across the board. On the 2 ends where the PPA logo and the LED output pads are, you should have clearance to drill holes to place screws to mount the heatsink. This will also apply pressure. I don't think you should do this but if you have the confidence and equipment, it will make you feel better knowing that they don't run burning hot.
