hotdogseller
- Sep 29, 2014
When did people start equating "burned in" with better sounding? It's not a ******* leather shoe, shouldn't this purported degradation of the driver produce less accurate sound?
Buy a pair of cheap Superlux HD668Bs, never-used.
Burn them in with 20 to 20k frequency sweeps for something like 200 hours.
At an interval of your choosing during the process, measure their frequency response with adequate equipment or even just some decent microphone stuck between the cups, even if they don't form a seal around it (and try to get your environment as close to dead-silent as you can).
Compare the measurements.
Then talk to me about your final verdict on headphone burn-in and how the changes are mostly inaudible.
1/if you have done so, please share your data.
2/ it is well known that the ear pads on headphones will change over time and affect the signature. so if somebody does some measurements they must be done at the exact same position, and it probably would be best to remove the pads for variation measurement purpose. unless we're saying that the pads are the burn in of headphone? then sure burn in is real it's been proved many times.
I know I wasn't kidding one bit when it came to my 668Bs, and Zeos doesn't sound like he's kidding either on the Stax: https://www.youtube.com/watch?v=1l0EtAF_lEk
should I talk about burn in for sponges, sofas, beds... ?
as long as we can be clear on the meaning I'm ok with it. just try not to pretend like you know it's the driver or the metal or whatever that changed if you have no actual evidence that it's not the pads or your brain.
As already stated, I do have the requisite evidence, since I burned them in on the table, not on my head, so there can be no discussion of pads giving in or the brain getting accustomed. Not to mention the little low-tech spectral analyses I did with my phone just to have that extra data. Yet I keep getting these "it must be the pads" comments, like people can't or won't read anything that goes against their preconceptions.
