Mr Trev
I just made three non-surgical mods to my Bravo. Actually I made them awhile ago but just did critical listening tests vs the Schiit Vali 2 recently with HD6XX HP. The three mods are: 1. Replaced the stock ps after trying 4 others with the LEDWHOLESALERS 24v 2.5 A ps it actually improved the low-end. 2. Added an additional 3300 uf cap on the b+ in an outboard box. Brings the total capacitance on the B+ to 10,100 uf. 3. Then swapped out the stock tube with an rca clear top 12au7a. These last two increased the low-end reach and better defined the high-end. The result is a much improved bass-slam and high-end detail. When compared to the Vali 2/6sn7 the sound quality is not better or worse but different in a good way. Not as delicate or refined but more forward and attention-getting. It gives me a choice now as to how I want to hear my music without giving up fidelity.
Kind of surprised to hear you say improved high end detail. I'd think with the way the stock mosfets roll off the high end way early there wouldn't be much hope. But the good thing with the Bravo (and variants) is they do run the tube without negative feedback so it could be that the tube differences are coming through far more than in the Vali2 - I don't actually own 2 of the same tube so I've never been able to compare the 2 amps. No idea about what that B+ cap is about, first I think I've heard of that mod
FWIW - I found the surgical mods are worthwhile
