TrollDragon
I really want to put the velours on beyer 990's and fostex t50rp
The velours sucked ALL the treble out of the DT880's so YMMV on the DT990's with the HM5 Velours.
From what I've seen the velour fits beyers horribly. It covers part of the opening of the cup.
I personally find the plaether pads sounding better.
Pleather gives a fuller bass but the heat over time kills it. This is a problem with all pleather pads. Because of this I've learned to like velour.
Yeah the real steamer......
Hey everyone just a quick question. I bought a used HM5 (originally purchased in September) and I am not liking the stock pads at the moment. They are not firm at all and feels like they are losing their shape.
http://www.mp4nation.net/brainwavz-replacement-memory-foam-earpad-dark-red-suitable-for-large-over-the-ear-headphones
These replacement pleather pads are not the same as the stock hm5 pads correct? If they hold their shape better I will order a pair to replace the stock pads and the stock takstar pro 80 pads once i receive those headphones.
see the pros and cons and decide by yourself. both these pads are nice, but in this cold, i am liking the pleather pads more then velour ones, do keep in mind that pleather pads will get generate more heat. both are firm and good to be precise.
You misunderstand my post. I already have the stock pads. I am just wondering if the ones in my link are the updated versions? I just found out that they are supposed to be different and was recently updated?
