I ended up only mid +2
Spacial audio is great for some tracks, but not all.
Thanks. Then these should fit my ears just fine.I would say it’s the same as the QC45 can’t notice any difference in size
I thought that Adaptive was backward compatible, but the information out there is confusing at best.Fyi, aptX adaptive is a specific CODEC; ie just because the source device supports AptX doesn't mean it supports all of its CODECs. Fwiw
Btw how is the overall spectral performance compared to the ML's? You mentioned bass, but what about mids/highs/spatial?
also, like with their older models there is no "ANC off" mode, only ANC on and Ambient on. meaning you can't disable it in the app or settings at all
I swear companies do this as a statement of "what we designed for you is so good and the best that you won't want to switch it off".GAME OVER right there. DUMBEST design decision ever, and the reason I ended up buying a clone of the QC35's instead of the QC45s. I wouldn't use either for actually listening to MUSIC - but most of my headphone use is listening to calls or videos or just hearing protection while I play drums, and ANC kills that. So NO THANKS, Bose, may your sales go ever further down until you smarten up.
