AudioThief
- Feb 15, 2017
Just a quick tip: If you're looking for really strong bass, you'll want to boost it via EQ and use an amp. There's great info in this thread. (Notice how the TH900 is ranked #2.)
https://www.head-fi.org/f/threads/the-hardest-hitting-headphones-are-the-extreme-bass-club.716711/
(Also, in case you didn't know this, you need to reduce the gain in your player by at least the amount of your largest boost/cut to avoid distortion.)
I'm one of those guys who really want my equipment to be stock, which means no EQ, no changing of pads etc etc. I put my faith in the engineers behind the headphones to create something good and I don't want to mess with it. But its definitely positive that th900 is at #2 in that thread But I definitely wouldn't be getting them ONLY for the bass, I have some 30$ headphones with some silly amount of bass although muddy and one note that can blow my ears off.
