Blon in ear monitors impressions thread
Apr 28, 2021 at 1:43 PM Post #5,596 of 6,129
My BL-Mini is in the country, I'll probably have it before the end of the week. :)
Apr 28, 2021 at 2:24 PM Post #5,597 of 6,129
Just get them, impossible to fit !!! the best i get is that....
And if i press them with finger i get some king of good sound but not possible to use them :slight_frown:
Apr 28, 2021 at 3:29 PM Post #5,598 of 6,129
Hahaha, is that the mini? If it is, that's interesting and it seems you have the cable the wrong way round on the right side. Of course I haven't got mine yet.
Apr 28, 2021 at 4:25 PM Post #5,600 of 6,129
Everything big here :p
The cable of right was wrong, after testing many tips i had one fit better, start to get some good sound but the cable won't be in place no matter this one or another
Apr 28, 2021 at 4:33 PM Post #5,601 of 6,129
Hahaha yes, I get you now. That's why I ditched the cable on the o3. I'm a big fella too, the cable pinched my ears and pulled them out of my ears, and the tips were baby sized, they went in the bin 2 minutes after opening the box.
Apr 28, 2021 at 4:41 PM Post #5,602 of 6,129
Nice, how is the fit? BLON has a rep for IEMs that don't really fit well, and this one takes the cake in terms of design.
Would also be interested in a BLON BL-01 and BL-03 versus BLON MINI comparisons. Thanks in advance!
I could only give a quick impression on "Fit", since I'm still working on my review for the NA2+...
Fit:
Now, for fit?...It was a little tricky at first, since I couldn't find the right twist and turn to put them in my ear. But, once I realize the right angle to insert them, and what was left from right, the fit was really good! The default silicone ear tips are small, so for those with medium or larger ear canals you might want to consider going with the included medium or large silicone ear tips. Overall, the fit is very important to know, since I could see many here making the same mistake at first, just like I have.
Below are some PIC's of the proper insert for them to be correct and comfortable. Though, to consider them as a sleeping musical buddy is totally up to you, the individual. Finally, for me, they are actually the first BLON to ever easily reach my ear canal and seal them with no problem what-so-ever!
Please study the insert method below for best results...
Hope this helps...
-Clear
Apr 28, 2021 at 5:37 PM Post #5,603 of 6,129
You find a cable who work so ?
Apr 29, 2021 at 2:39 AM Post #5,606 of 6,129
OK, my fellow head-fier's! The BLON BL-mini is here!
I've been listening to them for several days now and they punch way over their size and weight!!! They have an immersive bass impact and it's not about to be bullied! They are overall surprisingly clear with incredible upper treble with micro-details. Amazing, for such a small size and overall good fit! I would consider them V-shape. Yes, you heard me right! These are V-shape directly competing with the likings of CCA CSN. They have nice timbre like the BL03 and can put out better details when compared to the BL01. But, note that I don't have the BL05s to compare them to, though most people that own them say that they are U-shaped while currently the BL-mini are V-shaped. So, maybe I'll just try to buy the dreaded mint-green color after all.
Enjoy my PIC's! :beerchug:
WeChat Image_20210427164839.jpgWeChat Image_20210427164736.jpgWeChat Image_20210427164659(2).jpgWeChat Image_20210427164854.jpgWeChat Image_20210427164717.jpgWeChat Image_20210427164728.jpgWeChat Image_20210427164848.jpg
-Clear
What about sound isolation and sound leakage?
Apr 29, 2021 at 4:17 AM Post #5,607 of 6,129
Looking at your photos i would recommend a straight 2 pin cable with either soft earguides or without.
Yes maybe, but 2 pin are compatible with Blon ? i've read that TFZ/NX7 are fully compatible
And i'll need a Thin tube above the 2 pin, or the IEM will fall out
Apr 29, 2021 at 5:13 AM Post #5,609 of 6,129
I've only used the standard 2 pin connectors for about 5 months and haven't had any problems with them, they dont move around lacking the plastic sleeve.
Maybe you can bend the pins, but then again nothing has happen to mine even sleeping with the iems.
Also the only 2 pin interface uncompatible with blon unmodified is qdc.
Apr 29, 2021 at 10:16 AM Post #5,610 of 6,129
I use a 6 core bannned from headfi cable y***** it's £18 on Amazon UK. It's a normal 0.78mm 2 pin straight copper cable and is very thick and flexible, no ear hooks. It doesn't fit flush though.
My bl05 doesn't get an upgrade, as I dislike the tuning without heavy eq.
Can you list the product model? If it's anything like the TRN BT20 Pro that reads like great value.
It's the KZ AZ09 TWS.
