Gorktastick
- Mar 3, 2011
Thanks so much, I really appreciate it!
They are truly not necessary though. just fold up the tip and cut a millimeter or two off the base then slide that around the nozzle of the Iem. It functions exactly the same and it's free and you can cut it to the exact size you want. Do that mixed with flipping the tip inside out and it really is a good fit with a much longer nozzle.Thanks so much, I really appreciate it!
What does magic and romantic sound mean frequency wise?The BL05 with the stock mesh changed out for a Moondrop filter has slightly better technicalities and a better balanced tuning than the BL03 with mesh removed IMO, but it lacks the magic and romantic sound of the BL03, including with vocals. Even though it’s technically a bit better than the BL03, it is nothing special. If only the BL03 fit like the BL05. I have yet to hear the BL01 or BL05s.
I put these very o-rings on my Blon - 01 and they really completed the seal and in the process the isolation got better and the sound quality did also... Can't say which one I love more, 01 or 03...they are both Amazing in my book...
I think you will like the BL01 for what it is especially if you get a good fit and seal..The BL05 with the stock mesh changed out for a Moondrop filter has slightly better technicalities and a better balanced tuning than the BL03 with mesh removed IMO, but it lacks the magic and romantic sound of the BL03, including with vocals. Even though it’s technically a bit better than the BL03, it is nothing special. If only the BL03 fit like the BL05. I have yet to hear the BL01 or BL05s.
I've been a daily music listener for the past 7 or so years, with my first pair of headphones being the Shure 425's - Not a bad entry into audio. Over the past couple of years, I've slowly incorporated Bluetooth into my listening - it's simply an convenience reason. If I'm out & about, I'll prefer to use my Nuraloops or Sony XM3's paired with my LGV30 (which I have as a music player only).Yes BT and TWS seems to be where the newer generation of audio enthusiasts are heading. Majority of IEMs/headphones I see on the ears of consumers on the subway, buses and shopping centres seem to be TWS/BT types. My nephews and nieces only use wireless gear too, they refuse to consider any wired gear I recommend them.
I mean wireless gear is catching up with wired, no question about that, but the irony is that TWS/BT types get obsolete very soon due to new BT tech/codecs, and battery life also generally gets worse and worse with each charging.
Good enough for most is not exactly the headfi crowd though....when taking about sound quality.Bluetooth while not as good as a wired connection, it's pretty damn close & for many, good enough.
ewww, that looks like a shower drain, at a public poolA guy took the BL-01 apart and the driver's diaphragm is indeed biocellulose:
https://www.facebook.com/delta.fyre.3/posts/161784125694768
It’s okay, it’s not like you’re shoving that stuff in your ears.....oh, wait....ewww, that looks like a shower drain, at a public pool
Kinda looks like hair is stuck on it.A guy took the BL-01 apart and the driver's diaphragm is indeed biocellulose:
