JWFokker
- Mar 8, 2005
I was going to say, mine don't look that good without the jacket.
Originally Posted by Daroid The difference - I'll say bollocks. |
Originally Posted by JWFokker I was going to say, mine don't look that good without the jacket. |
Originally Posted by PinkFloyd Hi peter, I had a MKl WNA fitted out with Welwyn RC55Y and another MKl fitted out with bog standard 1% 50ppm metal films and I couldn't hear one bit of difference between the two amps to be perfectly honest. Sure, different types of resistors may sound better in certain applications but in the WNA head-amp they didn't appear to make any improvement.... or at least nothing that was obvious to my ears. Now caps, they are a different kettle of fish entirely.... |
Originally Posted by Emon But I think there's a fine line between upgrading to nice caps and just being ridiculous. I think Cerafines or Silmic IIs vs Blackgates is just...eh, doesn't seem like there would be that much of a difference, if any. I haven't heard either, but still...I mean just the price would be more than enough of a deciding factor for me. |
Originally Posted by pburke I found resistors to make the biggest audible difference in attenuators and to some extent around the tubes in my preamp. In my DAC there are two resistors per channel to set the vref, and matching them right down to 0.5% made a big difference, while the type of resistor was not relevant. I also like to use at least a Holco in critical voltage regulators such as the one for my DAC clock. In power supplies (tube gear) good wirewould resistors are usually a quite audible improvement, but diodes and caps are more important there. Peter |
Originally Posted by biovizier yes and the stepped attenuator has a total of something like 80 resistors only 4 of which are in the signal pathat any one time - one for each of left, right, hot and cold. So £500 to change one reistor in each of the four paths. |
Originally Posted by PinkFloyd I "personally" think all this "ppm" temp coeff in a resistor makes your amp sound better is a load of ********. In other applications "maybe" but in the WNA headamp? No way. |
Originally Posted by Emon That's the kind of thing I've been saying. I always get shot down. |
