Elysian
- Aug 14, 2011
What were the biggest differences you heard between the BH and DIY T2 vs. the LL prototype and WES? The WES seems to have its share of fans, though it seems to be more with the Sennheiser cans than the 007 or 009.
I wonder how much the GES has in common with the original KG design. Part of the reason I opted for the GES was because I liked the GS-1 and had hoped the GES retained similar characteristics.
The long and short of it is that all three KG designed amps trump anything else out there. The difference is not subtle. If you can afford one of these amps, by all means buy/build one. You won't be sorry.
