Around $5980 for wiredI know, what is the HKD price.
Around $6680-6980 for remote
Well there is no more wired version in Hong Kong,Mine cost me approximate HKD5880 for the wired version, got it back in January. If you can still find the wired version similar priced, it's cheap, it all depends if you want the in line remote, China is selling it for about RMB680 each, and the remote version, you get a better leather case.
Also the faceplate is slightly different.
I think they also fixed the loose cable problem so I better get the remote oneMine cost me approximate HKD5880 for the wired version, got it back in January. If you can still find the wired version similar priced, it's cheap, it all depends if you want the in line remote, China is selling it for about RMB680 each, and the remote version, you get a better leather case.
today i went to those retailers who said they have it and, nope,
not the wired version. Those are the remote version.
I think it is impossible to find wired version in Hong Kong now.
Also because beyerdynamic doesn't produce that anymore,
so I cannot order it as well.
Guess i'll buy the remote version then.
just an update: more often than not, I am finding reading while wearing there iem's difficult as the sound can be quite captivating. Beautiful bass; lovely pianos, strings and horns; clear yet musical vocals. Soundstage and layering improving over the hours, as well -- something notably lacking for me upon first listen when new.
Definite keepers.
Are you from Hong Kong?There are wired version available, you just have to look around, and price is the main factor for it.
Which shop did you go to.
Pls check your pm!yeh, i'm from Hong Kong, there is about 4-5 places that stock it.
Is there something wrong with my mic cable for the xelento? The mic barely pics up my voice, I literally have to turn it and hold it almost against my mouth to pick up my voice and even then it sounds pretty bad. Is it defective?
