Twizzleshnizzle
I've had both. I'd say Bokeh if you want timbre in your instruments (guitar for example). T5 if you want a slightly fuller sound and crisper notes. I'd say the T5 has slightly better soundstage and definitely better imaging due to the crisper sound. It's a pick your flavour scenario.Have Anyone compared t5 3rd gen with zmf bokeh?
They're both general use headphones in my opinion, neither are genre masters but both are good all-rounders.
Comfort is something to consider, the Bokeh has a more comfortable pad with more diameter for your ears. The T5 pad has a very small diameter that will likely rub on the bottom of your earlobe (I've got small ears and it rubbed). I've had the T5p.2 and the T5, I used Dekoni pads on both, but that of course means a slight change to the tuning. The Bokeh is heavier but not to the point I found it an issue.
From a sound perspective you can't go wrong with either, but if you're purchasing used the T5 is far more affordable. Without doubt you pay a premium with ZMF for the extremely beautiful build.
On a side note, I've also had the Atticus and Verite Closed. I had a Manchurian Ash Atticus and found it sounded very good, I also tried a stock Atticus and found it uncomfortably peaky in the treble. The wood made a big difference. The Verite Closed was close to being a genre master. Acoustic tracks with male vocals were insanely good. I rate both of those headphones (Ash Atticus and VC) above the Bokeh. Ash Atticus only just above...I think it pays to have a harder wood edition.
Apologies for the lengthy response.
