ryder78
- Dec 20, 2010
Hmm.. looks like I need to listen to the LCD2 and DT880 rather than putting the T1 at the top of my priority.
Thanks for the thoughts again.
I'll listen to the Beyerdynamic DT880/600, T1, Audeze LCD2 and Sennheiser HD880 soon and have a feel how all these headphones sound like. Out of all these cans, it is likely that I will end up with either the DT880 or the LCD2.
The T1 and HD800 are too much money (for me) at the moment, not to mention in a T1 vs HD800 review ASR felt these headphones are overpriced and should cost around $500-$1000 and not at their retail. To each his own I guess. Since the DT880 shares a pretty striking sonic resemblance to the T1, though not at a similar level, at its price point it does represent excellent value. As with most high-end headphones, point of diminishing returns will likely be evident. That may explain the miniscule sonic differences between the DT880 and T1. Although the differences are appreciable rendering the T1 to be a superior model, I can understand your thoughts and share the same sentiment of the lower-priced DT880 on a value perspective.
Difference between DT 880 PRO - DT 880 Edition - (PRO vs. Consumer)
The DT 880 PRO is designed for use in studio and on stage for professional use. It's headband has a more rugged construction (thicker material) and gives a more secure fit for the listener in comparison to the DT 880 Edition. This provides a better fit and causes also a more powerful compressed sound which is necessary for professional applications in studio, OB and FOH. The DT 880 Edition therefore is designed for easy listening. The headband provides a long wearing comfort for hours, causing the DT 880 Edition to have a more transparent and open sound in comparison to the DT 880 PRO.
The differences of both headphones are not huge in mechanical design, but only that small change causes a big difference in sound and application.
The following headphones:
DT 990 PRO - DT 990
DT 770 PRO - DT 770
have a very similar difference.
What are you currently using to power headphones?
Any plans on buying a new headphone amplifier?
