Thanks for the graph. It isn't as bad as I thought it would be but as you can see there is less content over 10 kHz when what is needed is more.
To be honest I have never tried the A pads. I bought these after researching and when I looked at the waterfall graphs at DIY Audio Heaven, I saw there was not only a peak at 8Khz but a lot of ringing on both the A and B pads. In fact there is a lot of ringing at 4.5 kHz, 8 kHz and 16 kHz. With the Dekoni Elite Velour, the ringing has been damped almost completely, also shown in the graphs. I burned them in for a week with the B pads, listening for a few minutes once a day. While I heard improvement, the ringing at 8 kHz rendered them unlistenable for me. Not only was there a huge peak but it was heavily smeared in time. After a week, I gave the B pads a real chance. Then I put the Elite Velour pads on and gave them a serious listen as well. My findings were well established in the beginning. The Elite Velour pads took care of the peaks and the ringing, but there were issues with attack and clarity; the sound was liquid. They sounded like Sennheisers with more bass to me. My first thought was there is foam in both the Sennheisers and the Beyers so perhaps that is the culprit, and I removed the foam. At that point they sounded unbelievably good except they no longer had the intoxicating bass, so I decided to order the Elite Hybrid pads and that is my story of the three bears, I mean pads.
I didn't notice the peaks with the Elite Velour pads with or without foam disks. The difference I noticed was without the foam disks, the SPL increased all the way down to 1 kHz leaving the bass anemic and above 10 kHz it was clear as a bell and relatively flat. This is a big bonus because most transducers have difficulty in that region. Manufacturers don't worry about it because most listeners either can't hear it or they don't care. What they don't want is a lot of ringing up there which people will care about. However, as described in the
white paper for the Tannoy super tweeter, any roll-off or peak causes phase shift so the transducers will sound much better if the response extends beyond the range of hearing. Another interesting aspect of this is it doesn't matter if it is mechanical or electronic so mechanical problems can be corrected with electronic solutions as long as the electronic fix causes a phase shift. This rules out FIR digital filtering as a fix, but IIR filters work great for this. I haven't read that white paper in over 20 years and I may be adding the bit about electronic filters, but I know them well and this is what they do. Given this, the extension in the lows and highs of the DT1990s makes them sound clearer even if there is no signal in that range and that is another reason I really like the DT1990s with Dekoni Elite Hybrid pad and no foam disk. However, to achieve the best sound they have to be EQed in the bottom and 8 kHz octaves, at which point, I don't think anything could sound better. I continue to be completely blown away. They also are capable of getting really loud without distortion; like ear damaging loud. They aren't as loud as the Grado HP 1000s but they are louder than they should be used.
Drop kept sending me emails about the new Dekoni Foam HF filter pack and I finally bought them when they said they were running out. However I don't plan to try them on the Beyers because as I stated somewhere, you can't control an 8 kHz peak with foam without attenuating everything above it which will cause phase shift.
I am far from my 20s, but my hearing is still excellent. I was at an ENT last year and I asked for a hearing test. The doctor said: "I see you haven't been exposed to many loud noises in your life". I didn't answer because that was far from the truth. When I asked him for more detail on the results he told me I have a slight dip at 5 kHz in my left ear. I like to listen to music loudly and I particularly don't like peaks in the 5-8 kHz range. I find them very annoying, and a lot of recorded music has a peak in this area. When mastering I am very careful with peaks but you have to have really good speakers or headphones to hear this correctly.
I have no way of measuring headphones, and even if I did everybody's outer ears are different so there really is no reference for that particular frequency range on headphones. I adjusted the 8 kHz cut listening to tape hiss. I am very familiar with 15 IPS tape hiss so it was easy to tell if there was a peak or a dip. Anything more than 3 dB caused a noticeable dip in the hiss with 2 dB having an almost unperceivable peak (except at maximum volume) with my ears. Someone else's ears will be a little different.
I have to add that I use those Tannoy super tweeters, which I believe are manufactured by Focal, on my mid field system which consists of a pair of Focal powered subs toped by a pair of Tannoy System 600s and a pair of the super tweeters. They are also wide band, very clear sounding and except for the deep bass they sound similar to the Beyers with the Hybrid pads and no foam disk. I don't think my big system goes that deep and it has a Kinergetics sub that consists of 10 x 10 inch drivers. They come in a pair with 5 on each side and were designed to compliment planar magnetic speakers. They sound better as a single sub, but I've been told two pairs of them is the best. Unfortunately, I don't own a second set.
Here are some photos and a description.
I hear the soundstage much better on the Tannoys than I have heard on headphones. The Tannoys sound like the stage is bigger than my room, so for sound stage I have to defer to speakers rather than headphones.
