ROBSCIX
- Aug 25, 2005
I have been doing alot of reading lately on connections for S/PDif and electrical charachteristics of each. There seems to be alot of disagreement as to which is the best connection method for a S/pdif output to an external DAC.
Many suggest it is optical, no possibility for any interference through EMI/RFI and no electrical connection to the source.
Others suggest it is Coax, you take the optical receiver and transmitters out of the equation which can be of low grade.
Also, some suggest that BNC is the way to go.
I came to the conclusion that each connection methods has both pros and cons but there has to be more to it.
So, I was wondering what experienced people think is the best method for connection and what are their reasons behind it?
