Best way to hook up a home amp to receiver?
post-1438183
Thread Starter
Post #1 of 9
wakeride74
I am wanting to lean away from using the RCA to mini and wanted some direction on hooking up my home headphone amp to the receiver.
I have my DVD player (which I also use for music) and an Xbox (both running through the receiver). I'm using Coax for the DVD and Opt for the Xbox, do I have any options here??
I've tried a few things but I can't seem to get any sound the way my rig is set up. Feel free to take a look at the back of my amp here and make some suggestions, thanks!
post-1438189
Post #2 of 9
rickcr42
Are YOU talkin' to me?
straight from the record outputs (tape out) which is no more than a feed from the input selector
post-1442178
Post #3 of 9
heavyharmonies
Actually, I would use the left and right preamp outputs (assuming you're not using the Receiver to also power a speaker system).
-Dan
post-1442280
Post #4 of 9
rickcr42
Gain stage into gain stage is not a good idea.
Any noise produced by the preamp (and all electronics have noise) will be amplified by the gain of the headphone amp.If that headphone amp gain is X10 then the noise will also be increased X10.
A voltage follower/unity gain buffer amp could be used after a preamp but a headphone amp that already has a gain stage should only be connected this way as a last resort.
even then i would avoid this method of connection and find another way.
post-1442308
Post #5 of 9
wakeride74
I may have to mess with some of the programing to run "tape out" because I tried that and could not get sound when just playing a cd on my dvd player via "coax in" and "dvd coax in assigned" or by selecting tape out on the receiver.
I could have taken stoopid pills prior and am missing something obvious but I will have to toy with it a bit.
Thanks for the assist
post-1442392
Post #6 of 9
rickcr42
I have never owned a receiver that did not have active record outputs at all times so that is a strange one.Are you sure you are hooked up to the record outputs (tape output) and not tape monitor which is an input ?
post-1442834
Post #7 of 9
wakeride74
I thought it was but again I could have been on auto pilot or something. I believe that the problem may have something to do with the programing being set to read the "coax in" as DVD... maybe it should be read as CD to make the "tape out" talk to the other chanel... I dono but I will play with it this weekend.
post-1442873
Post #8 of 9
rickcr42
hmmmmm.....
DVD players the coax out only works if you set the player to use "dual outputs" so you have both a line out for DVD and a digital "PCM stream" for the coax spdif.
I think this is source related and not a problem with your receiver at all.Check the DVD player menu for the fix.You need to check the "PCM" box in the menu
Rick
post-1442920
Post #9 of 9
wakeride74
hmmmmm.....
Rick
good call, you are probably right... thanks for the help (fingers crossed) I'll give it a shot this weekend
