Ozer
- Jul 5, 2009
I'll be buying Dacmagic next week and I want to know the best way to connect it to my PC... I'll not use USB... I have a Auzentech Prelude soundcard right now, while it's good, it doesn't support 24/196 digital out... I don't care about sound in games and all that, I just care about the sound of my music, my soundcard have a lot of options, but i think all are for gaming or something that will degree the sound quality... So really what do I need the soundcard for ?
I want to connect my Dacmagic with an optical cable somehow, but the problem is that my motherboard doesn't have an optical output, so if I don't want to use my soundcard, I have to buy a USB>Optical adapter ? like the m2tech hiface...
Can't you buy a little cheap card that you place in a PCI-slot, witch only has digital outputs ???......
