ah okay. hopefully stock EQ on spotify works atleast.No you can't install any audio mod because recovery is locked
Best Smartphone for audiophile Part II (Updated: Jan 2020)
- Thread starter artpiggo
- Tags
- smartphones
Vympels
- Dec 13, 2016
Nope it will redirect to native oneah okay. hopefully stock EQ on spotify works atleast.
Native as in the spotify ‘basic’ eq or some meizu system eq? I can deal with the spotify eq ive used it on ios for a year even if it’s pretty meh.Nope it will redirect to native one
Vympels
- Dec 13, 2016
Stock flyme
I’m reading that the meizu will only use exynos dac with spotify and not the dedicated hifi dac?
There was a link to a mod but it’s dead so I’ve no idea if there’s a fix for this or not.
If that’s true and there’s no workaround I may aswell look for another phone since spotify is my only music source.
so many things to consider just to assure good sound quality... lol
EDIT: nevermind apperantly spotify was added to the list of apps that use the hifi dac in an update to flyme OS... PHEW )
Meizu Pro 6 plus is considered as neutral. series 6 and 7 use cirrus logic dac-amp combo
while mx4 pro and pro 5 use Ess9018 with OPA1612 which is into warm tone.
Neutral and full sound? or on the thinner side? Really appreciate the input thxMeizu Pro 6 plus is considered as neutral. series 6 and 7 use cirrus logic dac-amp combo
I’m coming from a iphone 6s which I consider full and neutral-slightly warm with a tiny bit of midbass bloat but honestly it wasn’t too much. I liked it’s tonality. LG v20 was too thin and somewhat lacking body in the mid range to me, although detail was good.
I don’t know anything like 6s with more detail and bigger stage and separation but if I did I’d buy it ASAP.
Sorry had to double check your list but does the pro 6 plus not use ESS sabre dac?
And pro 6 uses cirrus logic dac as you say.
Does that change the info about neutral or warm that you said above? and is it full sounding (pro 6 plus ess sabre dac).
Thanks!
Thanks!
Oops sorry for wrong brain memory. Pro 6 plus use ESS dac with AD45275. It is neutral and less full than pro 5.
If you want V20 to have fuller sound, you can use some trick to activate external mode by attaching a cable first then attach the earphone to the cable. You can see detail in first page
tried that but it’s not ideal for my 16-32 ohm earbuds and it didn’t make a hugh difference for me, just slightly more bass impact and maybe slightly less cold.Oops sorry for wrong brain memory. Pro 6 plus use ESS dac with AD45275. It is neutral and less full than pro 5.
I may have to look at Meizu pro 5 then thanks, unfortunately because the 6 looks like a great phone lol
Ok I bought a pro 5 for €250. Only one I could find anywhere, let's hope it’s the right call
I got myself a Pro 6 Plus and it's indeed neutral .
Comparing to my Shanling M2S, it sounds crystal clear , there is a lot of details, while remaining powerful.
With a Focal Spirit Professionnal ( which is neutral by essence ) , it's awesome !
Navigation is 10 times better than a non tactile DAP : when i use the Shanling after the Meizu, it's like going back to the Jurassic Era.
It's fast, screen is huge ( good for high quality album cover), you can switch easily from song to song , album to album, make real time playlist...
And it's Android : you can find another music player if you don't like the stock one, i personnaly use Captune (by Sennheiser).
How would you describe the lower mids or vocals in general? Do they have authority and weight behind them? I opted for the pro 5 for this reason but it’d be nice to know how the pro 6 fairs too.I got myself a Pro 6 Plus and it's indeed neutral .
GermanDrifter97
- Dec 2, 2016
Where did you buy yours?I found the Pro 5 for 247€ on trading shenzen
Vocals are clear , you can hear them distinctly and efforless .
I'm not good at describing audio precisely lol .
All i can say is high, mid and low are where they should be ,none of them has the upper hand over others .
Total: 9 (members: 0, guests: 9)
