John,
Thanks so much! Very close to pulling the trigger. I have a question in regards to some of the functionality.
1. How does the wireless connection to the app work? My system is not near my router so I am concerned if I have to hardware the LAN connection
2. Are the drives user swappable? Either for upgrade or failure?
3. Is there any ability to adjust files tags? Or must all that be done and then transferred onto the Aurender?
4. Is there any way to wirelessly add files?
Thanks so much!!
1) It just has to be on the same network. Most people usually have wifi, and use it for their tablet. So that's already in place. Now it's just a matter of feeding the X100L with an Ethernet cable - which is a necessary component, as the X100L doesn't have built-in wifi.
If you can't run a cable direct from your router, then you still have some options. You can use a PowerLine adapter which carries the signal over your home electrical wiring. You can use a MoCa bridge which does the same thing but uses your existing coaxial wiring (ie your cable TV wiring). Or, you can simply use a range extender/bridge type device like
THIS which joins your main wifi and provides Ethernet connections to individual devices. Not all of these work in all homes, but between the three types at least one should do the trick.
2) The drives are indeed user swappable. They use Western Digital Green drives - X100L gets a pair of standard 3.5" drives while the X100S gets a laptop-style 2.5" drive. I have heard of at least one person upgrading to dual 4GB drives for the X100L, and apparently it worked just fine. Since the drives spin down when not in use they see far less stress than they would in a normal PC or NAS setup. This is related to the on-board 128GB SSD drive, but I'll explain it more in the full review.
3) There's no tagging ability from the device. It's meant to work with a pre-existing library. I recommend
Bliss to quickly and automatically maintain your library. It doesn't necessarily look like much, but it works very well in my experience.
I have heard from Aurender S10 users that you can actually connect an external USB CD drive and the device will automatically rip it for you. It uses FLAC and tags via one of the free internet databases. My experience with auto tagging via those databases is not stellar, so this method probably involved editing anyway. Personally I'd rather just use my desktop PC for ripping and tagging.
4) Once you have the Aurender on your network - using any of the methods I discussed above - it will show up as a network drive. So you just drag files from point A to point B, just like you would using a NAS or even copying files from one internal hard drive to another.
Depending on your network speed, this can be fairly slow or pretty quick.... but either way, once your transfer your existing library, it's a done deal, and future transfers will be smaller (just the new music you acquire). So it's not too terrible even if it initially takes a full day or two for the initial library transfer.
