Best isolation for not too much cash?
May 23, 2009 at 4:58 PM Thread Starter Post #1 of 22
scuttle
Hi! I'm having to parent sit (the old guy is pretty sick) and I need a pair of IEMs with ***great*** isolation so that I
1. Can get some work done
2. Can keep out the sound of TV news played 18 hours a day
3. Don't throw the TV out of the window
4. Don't commit patricide and end up on the news
The music I'll be listening to is not terribly high bit rate WMA and MP3, so there is no point in going for great sound quality, but I do want great isolation. My first thought after flicking around Amazon was CX300s. Would I get significantly more isolation from j-jays, CX500s or whatever? Isolation, as easy re-supply of earbuds (or the "olive" style ones referred to in the Tachikoma's* convenient sticky thread) and low cost are my priorities.
(*The blue robot spider guy. I have one on my Netbook's desktop. They're cooler than rat-things or Daleks - and don't even mention Governators.)
May 23, 2009 at 6:02 PM Post #2 of 22
Etymotic ER6i has some of the best isolation on sub$100 category.
May 23, 2009 at 8:00 PM Post #5 of 22
Originally Posted by mark2410 /img/forum/go_quote.gif
well u didint say where u are
Yes, Mark, I did forget. Excellent reading skills! I don't know how deduced that from "I forgot to say that I'm in the UK."
you dont give a budget either
I'd have thought that naming CX300's as the bottom of the range I was considering and J-Jays as the top would given a pretty good idea. It's definitely a fuzzy range: if I could lock out significantly more sound for an extra £25 I'd spend it.
May 23, 2009 at 10:32 PM Post #8 of 22
Hi scuttle -tell you what - I'll sell you my E2c, they'e in very good shape, come w/ olives (I'll fit new ones, natch) and they isolate pretty well. In fact, very well. I'll dig up an Ety pouch for em too.
Oh, & I'm in the UK too
May 24, 2009 at 12:36 AM Post #10 of 22
meh, be snippy then. im not the one asking for others help
Whining and online rattle throwing aren't help.
But to everyone else - thanks!
May 24, 2009 at 12:56 AM Post #11 of 22
You're the one who started acting like a brat. He simply said you forgot to mention a few important details and you get on a high horse and throw condescension in his face with oh so clever sarcasm.
I don't have a problem with it, but since you're extremely new I would probably not act all high, mighty, and innocent. Act however you'd like, but I doubt you'll find acting in such a way will benefit you in the long run here.
Not to mention, he did give you a suggestion despite your omission of necessary information.
Now, onto the task at hand. The CX series does not isolate much. If you don't care about sound then I'd probably look at the Shure SE series, lower end models. The E2C should be good too, depending on the tips used but it's been a while since I had them so I can't remember. Didn't they used to come with those yellow foamies? Those worked pretty well, I think.
May 24, 2009 at 2:48 AM Post #12 of 22
The JVC marshmallows with the large marshmallow tips isolate quite well. The sound quality is OK (not great, but OK) with a bit of boomy bass, but they are only about $15 (10 UK pounds?) and are available off the shelf at lots of shops.
May 24, 2009 at 5:45 PM Post #14 of 22
No, that's not what he did. Although I suppose that either love or poor social skills might blind you to the difference.
You mean the necessary information in my two posts previous to his?
I'm puzzled by IEMS differing in isolation so much. Surely this is down entirely to the plugs? If so, given these are replaceable, how come there aren't independent plugs that can change isolation? It has to be the least challenging hi fi mod ever. I've adapted 3M earplugs to fit awful Koss Sparks in the past - snip 'em, freeze 'em, poke 'em with a hot needle.
May 24, 2009 at 6:55 PM Post #15 of 22
I am not an audio engineer nor do I play one on TV!
That said I suspect that achieving great isolation is like so many other endeavors - it takes 80% of the effort to get that last 20%. I know from personal experience that seemingly minor changes in the plug (type of foam for example) or degree of insertion make significant changes in isolation and sound quality. I'm sure the same applies to the driver housing, etc. Quite a balancing act these engineers go thru.
