PiccoloNamek
- Apr 1, 2006
Perhaps your definition of "neutral" is different from mine, then. For me, having a flat diffuse field response is as neutral as it is going to get.
It's quite simple. A completely flat bass response will give you exactly as much bass there is in the source recording itself. No more, no less. This is important when working with sound. Anything more will give you more than what actually exists in the recording. For simply listening to music, this is a matter of preference, and has nothing to do with anything versus anything or what is better. But when you're working with sound (I do) and you need an accurate representation of what is actually there, a flat response is crucial. You also seem to be confusing bass extension and bass amount. The ER4s have very good bass extension; all the way down to -3db or so at 20hz. The amount of bass is very flat and neutral, however. But that is okay, because they were intended to be this way from the beginning.
Decay is primarily a function of the recording, not of the headphone. Perhaps other headphones are artificially extending the decay? I have never noticed this "decay" problem on my ER4s. I can hear cymbals accurately fade into silence, along with every other instrument.
Daniel Pumphrey put this more succinctly than I ever could:
And if you had actually ever read anything about the ER4s, you would know that they actually boosted the highs to achieve the flat response the Etys have:
Perhaps, perhaps. But I have other reasons for having the ER4s than simply listening to music. As I said, a flat frequency response is important for the work that I do. When I am working on a particular waveform, and play it back, it needs to be as true a representation as possible of what is actually there, of how it actually sounded when I heard it live. The Etys do this for me.
I maintain that the large majority of people will indeed find them to be "better" for one reason or another, but that they are not absolutely better, yes. I would still maintain that even if I had heard them and liked them.
Is that your way of saying you can't answer my challenge?
This is simply wrong. A nonflat bass response is, by definition, inaccurate. This has nothing do with with the UE-10 versus anything, it is simply a fact. Perhaps it may sound more accurate (pleasing?) but you are still getting more bass from the headphone than the source recording itself has. For listening to music, this is not a bad thing, and I engage in it often. I do love my Grados, after all. But for actually working with sound and music, it isn't a good thing.
As for the highs, I've already gone over that.
I've only used one multi-driver IEM, and it was nowhere near the UE-10 pro, I'm afraid. I have never found my ER4s to be harsh, or fatiguing. I have no problem listening to them for hours at a time. (Which I regularly do when working.) But then again, I also don't find Grados to be harsh or fatiguing either, and they have far more treble energy than the ER4s.
Exactly. They are better for the vast majority of people.
Maybe they're just insane!
I never intended for this to evolve into a technical discussion of the UE-10 Pro or the Sensas, or ER4s, or whatever. If you go back to the beginning of the argument, you can see that my original objection was a philisophical objection to the assertion that because one (or many) people find a thing to be of a subjectively better quality, the thing automatically becomes better on an objective, absolute scale. That is the core of my argument. Not that the ER4s are superior, or better than the UE-10s (or anything else, for that mater). I still maintain this argument.
And with that, I will have to gracefully (?) excuse myself from this discussion.
Originally Posted by dmt1 Yes, I know the arguments about crossover frequency, but if you think a single driver can present everything in your music, you're sadly mistaken. It can't. That's the whole principal behind the multidriver IEMs in the first place. UE 10 is probably the most neutral phone there is--definitely more neutral than the ety's--it's not even close. |
Multi drivers does NOT inflate the bass. Extending it does not inflate it; it's not bloated. You hear what is supposed to be there; it's not adding anything (I don't know where you're getting this)--the single driver IEM's are missing it in the first place. |
In fact, there has been much talk on here of the Ety's adding artificially (you guessed it, to the highs. Not to mention that the ety's artificially increase detail by decreasing decay--it's a neat trick, and I like the effect, but it's anything but natural). |
![rolleyes.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/rolleyes.gif)
When I listen to a low note from a pipe organ, the proper Musical response from the headphone will be a note reproduced exactly when it appeared at the output of the amp, or to be more exact, the beginning of the headphone cable. No lag time is acceptable. When the note stops, the headphone must stop vibrating and not continue. This is essential for musicality to apply. The other aspect of Musicality I think is important is that the previously mentioned note from the pipe organ must be reproduced with the proper harmonic content and tone without peaks and dips being present. Often when listening to other phones (other than the ER4) I have a different result with the same given note from a pipe organ. There is a slow "note on" as musicians identify it, or a lag in the response time as others identify it. This lag is also continued for the upcoming note-off event. This lag time does not create "Musical" warmth to me, quite the contrary, it actually produces a blurred note. |
Originally Posted by D. Wilson On the ER-4B we actually boosted the high frequencies a bit to achieve a flat diffuse field response. This response is measured in a zwislocki coupler (db 100) real ear simulator. It is a few tenths of a dB different than the ISO standard real ear simulator. |
You really need to hear a good multi driver IEM. Until then, all you're doing is making snap judgements--they are that much better. You will pick things you never knew were there in a good recording with a set of good IEM's. When you go to the ety's for the first time, it's a common occurence--people will notice a detail they never heard before. Going from the ety's to a better IEM takes this a step further. Again, it's not that the better IEM's are adding anything; they're just presenting what the ety's cannot physically do. |
The majority of people will/have found the multi driver IEMs to be superior to the single driver; that's really the bottom line. If someone was looking for info on these--which a large number of people here do--that's going to be the overwhelming opinion. Now if you want to get into value, that's a whole new arguement; although the UE10's are worth it to me personally, are they six hundred dollars better than the ety's? Probably not. It doesn't change the fact that they are better--or that you haven't heard them, but maintain they aren't. |
There are very few absolutes in life; you're losing the forest by concentrating on a few trees...It's really not a practical argument anymore--it has no worth, because it's beginning to get down to semantics. |
The UE10's are more accurate than the ety's--slightly more so in the highs, significantly more so in the bass. |
They are less harsh and fatiguing (Once you've listened to a multi driver IEM for a period of time and go back to the ety's,you'll know exactly what I'm talking about). |
The bass is more forward, less recessed, but not bloated (The UE5C's however, definitely suffer from bloated bass.). The vocals are slightly more forward on the UE10's--not better or worse, just a sound signature difference. So yeah, the UE10's are better for the vast majority of listeners who get into the ety sound signature--like myself. |
And for the one's who prefer the ety's over the UE10's, I've always wondered if fit was an issue--again, it's like color TV vs. black and white--I really have a hard time believing someone would prefer the ety's over the UE10's or Sensa's. |
![etysmile.gif](http://images/smilies/http://hfimage.head-fi.org/smilies/newsmiles/etysmile.gif)
I guess my whole problem with what you're saying in this thread is you're making judgements on phones you haven't heard (Kind of taboo around here), and it's compounded by the fact that your sound signature preference is in the minority. Mine is too, I prefer the ety sound signature to the Shure sound signature--and although the ety's have a fanatical following, I don't think it's a majority here. So I don't think I'm on the same page with most people with regard to sound signature, but (no offense), I'm not sure you're even in the same book. |
