If you like bass heavy sound, I dont think that AKG q701 is the best option, although maybe this model has the most percievable bass among AKG headphones. O2 theoretically drives better, allows higher and tighter sound, but whether you would hear the difference, is the difference compensate for the extra cost and hassle with an additional bulky gear, or you percieve the change as a better sound is an open question. I would look for a 32 ohm headphone, which does not require additional amplification (and put the money into buying a better headphone hoping the pricier is the better) from models that noted for being bass heavy, like Denon or Beyerdynamics. Actually, I heard at a friend of mine the Denon AH-H100. Wonderful and beatiful piece, if you can find one. The wooden cup or the construction makes a wonderful sound. But also you may think on alternatives. For 200-300 usd you may buy a fairly good IEM, which also does not recquire amplification. I would certainly think to buy a stax sr001. Stax is a different class of headphone, while senn or akg just sidesteps with different colorations within the same sound retrival mechanism.
