cmhyt
- Oct 6, 2007
ep630,,
cheap and good =_=|||
Originally Posted by suba3333 /img/forum/go_quote.gif I also recommend the Creative ep630. Whereas the CX300 has a J cable the ep630 has Y cabling which I find much better, especially for sports. I wear the cables over the ear and use a homemade slider (piece of thread) to tighten the fit around the neck....works great for running/biking/gym. It's worth noting that the IEM design of the ety er6i transmits microphonics much more than something like the cx300/ep630. Also the complete isolation you get with the Etys might not be such a good idea if you exercise outdoors and need to be aware of your surroundings. If you want better sound quality with great bass the Denon C700 is a fine earphone, however I find it a bit too big for sports....would have preferred the C500 which has now been discontinued and replaced by the C551 which unfortunately has the cable extension connector which I find very unsuitable for sports (unless you wear an armband). |
Originally Posted by DARKHAVEN /img/forum/go_quote.gif ...... I'm looking for a pair of 551s or 751s to play with and they are within my price range, but those things are so heavy! As you said, they would not be good for exercising, especially running. I want a pair to play with anyway though... |
