Davesrose
- Oct 20, 2006
For landscapes, I do most of my shooting standing up
But good point that you should move around in all directions to find the "best" composition.
Also, it should be clarified that bumping up ISO is not the first thing you should do to prevent motion blur. Motion blur is a result from a slow shutter speed....bump up your shutter speed to something over 125 (even faster if its a really fast moving object your photographing). Usually, high ISO is needed for low light situations where you need a faster shutter speed. If you're looking for the best detail in a nighttime shot, then a slower shutter speed with a tripod is optimum.
The problem with filters is that some people forget that they're on and get confused if they get flare ups....since I don't photograph in sandstorms, I don't worry about scratching my lens (my lens cap stays on the lens when I'm not shooting). I only use a filter when it's called for (UV and CPL for landscapes). Yes, I'm a lens nudist and I feel free
Originally Posted by MD1032 /img/forum/go_quote.gif As for technique, believe it or not, I've found out one trick so far: basically every perspective except just standing upright and holding the camera makes a better photo. |
