Pokemonn
and or check your EQer setting of your softwares. boosting some FRQ may cause clippings too.
Your headphone drivers are probably over-stressed. Listening too loudly, or perhaps time to renew the drivers/HP. Alternatively, check your HP amp.
Saint-Saens 3: Charles Munch/Boston
Mahler 8: Boulez/Staatskapelle Berlin; Solti/Chicago, Vienna Staatsoper Chorus
I don't use any DSP or EQ. Software used are jriver on Windows and Audirvana on Mac, also tried CD player too, got same result.
I has these 2 CDs. They are probably best performance but SQ are OK but not great.
Saint-Saens 3: Charles Munch/Boston, the second movement at the beginning and ending, when organ bass is loud, it has lots of overloading/saturated sound I heard from headphone but not clearly from speaker.
Mahler 8: Boulez/Staatskapelle Berlin; Solti/Chicago, Vienna Staatsoper Chorus, basically the last 30 seconds is unbearable, badly clipped, both heard from earphones and speakers. I believe the originally recording on tape was already bad.
A week or so ago I suggested Pogorelich's English Suites and decided that I should listen to it again myself. So I was in a Bach kind of mood when I saw a recommendation for Jory Vinikour's Partitas. While I generally prefer piano to harpsichord performances, I went for it and am glad I did. The sound on this 3-CD set is glorious. Sono Luminus, DSL-92209.
HvK s-s 3 is good to my ear...
Perahia's French Suites are wonderfully performed, and the sound is excellent in the 96/24 downloaded FLAC files (from Prestoclassical).
Got Levine/Chicago doing Saint Saens' 3rd at 96/24 from Presto (cheap too). The organ was the one at Chartres, which is a magical Gothic cathedral and town -- so some sentimentality here for me. Along with Munch, probably the best version I've heard yet.
Looking on prestoclassical.co.uk and not sure if I'm finding the recording you've recommended. Can you provide a catalog number, upc or other ID number?
Thanks!
