echoplex
What do folks here recommend as best overall and/or best value replacement pads for the AKG K240 DF? I find the stock pads uncomfortable and not thick/deep enough to allow sufficient clamping pressure to my (apparently small) head.
Do your favored replacement pads change the sound and/or the imaging or soundstage presentation? If so, how?
Any tips on how to increase the clamping pressure other than by using thicker ear pads?
Thanks for any advice!
