I have not heard both... not even one of them. We all mostly agree that the 600 ohm model is probably not the best choice, and probably offers miniscule to no difference.
However, different ohm headphones respond to the same amp differently. You wouldn't use a Bottlehead Crack on the 32 ohm model, though it would be great with the 600 ohm model. On the same amp, the higher ohm model should have a higher damping factor, less THD, and perhaps a different (more flat) frequency response if the output impedance of the amp is very high when coupled with the non-linear impedance across the driver. [Not knowing coil structure, I cannot comment on the influence thereof.] These are all objectively measurable. Would anyone notice? Probably not. Is the 600 ohm model even worth considering in any circumstance? Other than when using an OTL amp, I'd feel safe saying 'no'. The 250 ohm version actually is the most sensitive per mW IIRC, and should play nice with many sources.
I have no doubt cel4145 heard a difference. It could be due to any number of factors... it could've been something as wacky the weather. (No joke... you can see the effect of weather when Tyll was doing some AKG Q701 burn-in tests.) It could've been the higher impedance. I do not, and probably will never know. He has a good reputation around here, is a wealth of knowledge, and of a helpful and generous spirit... so I'm quite inclined to believe him when he says he heard an improvement, no matter how small.
I hope that clears up my view.
