Quicken
- May 12, 2005
Thanks Herandu,
I've had emails from Stanley this morning confirming basically what you have said here (Sunday morning service - can't beat that). So it's a design decision made for sound quality reasons. Personally, I don't like it, as I bought the DAC primarily to improve my PC head-fi experience.
Cheers,
Q
Originally Posted by Herandu /img/forum/go_quote.gif It's obviously not using muting transistors at the outputs, which I would guess are not DC coupled as well. Muting transistors can distort the sound even when they are on the OFF state. Many of us quite happily whip out the old soldering iron and physically remove muting transistors from any audio outputs just to make sure the sound is not distorted by a final hurdle at the output. I suppose they could have used a relay instead, not taking cost into consideration. But from my experience with relays in small signal audio paths such as was found on the more expensive tape decks, they can cause their own sets of problems. I have come to accept it as part of the quirk design of the TC-7510. If you do mainly headphone listening then it might not be the best choice for you. Have you emailed them to ask if there is a mod, or if they ever come up with a solution in the future you can get them to do it for you? If the DAC sounds good other than that, then it is worthwhile considering that option. I had my MKI upgraded to MKII free of charge once I actually asked. So it won't hurt to try your luck ![]() |
Thanks Herandu,
Cheers,
Q
