And volume control is not there, on AHB2.
Benchmark HPA4 Headphone / Line Amplifier Impressions
- Thread starter negura
ahb2 is power amp, hpa4 is headphone amp. u can't plug headphone directly on ahb2 unless you utilize the speaker taps.
Well, assuming you use speaker taps, is there any difference between the HPA4 and AHB2 in terms of architecture or sound signature? Of course, AHB2 can give you way more power for hard to drive headphones, but I'm wondering if there's any other difference.
briantrinh86
does anybody have chance to a/b test the hpa4 with the amp xiaudio formula s+ powerman?
not really sure. i don't own or even tried ahb2.Well, assuming you use speaker taps, is there any difference between the HPA4 and AHB2 in terms of architecture or sound signature? Of course, AHB2 can give you way more power for hard to drive headphones, but I'm wondering if there's any other difference.
I was hearing that the HPA4 may have some issues with treble glare due to the THX architecture. Is there any merit to that? Or is it just people who are very sensitive to higher frequencies?
phthora
The HPA4 only has issues with treble glare if the headphones have treble glare. Actually, headphones that generally have treble glare (or muddy bass or congested soundstage or any number of other musical maladies) don't have quite as much of that smearing with the HPA4. The control and resolution that the amp provides reduces many of those such issues related to distortion or blurring of sound. If you are coming from an amp that is slower in the bass or warmer overall, the HPA4 might sound brighter to begin with, but really it is just more transparent. So, it won't artificially deaden those treble peaks, but it will often make them more tolerable just by presenting them so cleanly. If the headphones do have treble glare, IMO it's best to stick with the most capable and transparent amp you can afford and use an EQ program to address the specific frequency issues of the headphones.
Makes sense. I guess those people just weren't used to super transparent amps, and were sort of used to the "coloring" that less engineered amps usually do to tame the treble a bit.
And does the HPA4 pair well with tube pre-amps?
Hi the HPA 4 is pure linear amplifier that based on science and measurement. So there is no added or alteration going on, what you are hearing is what you get, from interconnect and cables, music recordings, headphones and your dac. So mileage may vary some might find too neutral and boring and some might find clinical and harsh with that treble depending on headphones. Its a perfect monitoring amplifier and evaluation of audio gear, of course music as well. This beast will expose the flaws of the recordings and your other source such as your headphones. Pairing HPA 4 with Class A solid state will be a dream of having best of both world.The HPA4 only has issues with treble glare if the headphones have treble glare. Actually, headphones that generally have treble glare (or muddy bass or congested soundstage or any number of other musical maladies) don't have quite as much of that smearing with the HPA4. The control and resolution that the amp provides reduces many of those such issues related to distortion or blurring of sound. If you are coming from an amp that is slower in the bass or warmer overall, the HPA4 might sound brighter to begin with, but really it is just more transparent. So, it won't artificially deaden those treble peaks, but it will often make them more tolerable just by presenting them so cleanly. If the headphones do have treble glare, IMO it's best to stick with the most capable and transparent amp you can afford and use an EQ program to address the specific frequency issues of the headphones.
I think there is a difference if you paired with super hard to drive headphones where they need slightly more power than the HPA-4, I mean after all AHB2 is a powered amp for speakers. Not all headphone can benefit from AHB2 of course where they might be distortion. Can anyone testify this statement ? Because am generalizing from experience with headphone amps and speaker amps when paired with inefficient planar.Well, assuming you use speaker taps, is there any difference between the HPA4 and AHB2 in terms of architecture or sound signature? Of course, AHB2 can give you way more power for hard to drive headphones, but I'm wondering if there's any other difference.
agree. In addition, the treble glare they're hearing could also be some hardened earwaxes on their ear canal which creates a wheezing, high-pitched sound.Hi the HPA 4 is pure linear amplifier that based on science and measurement. So there is no added or alteration going on, what you are hearing is what you get, from interconnect and cables, music recordings, headphones and your dac. So mileage may vary some might find too neutral and boring and some might find clinical and harsh with that treble depending on headphones. Its a perfect monitoring amplifier and evaluation of audio gear, of course music as well. This beast will expose the flaws of the recordings and your other source such as your headphones. Pairing HPA 4 with Class A solid state will be a dream of having best of both world.
Is it ? I never knew about this, is there any science and evidence regarding your supported statement ? This is the first time am hearing. But this kind of statement and discussion going out of the topic of audio and music enjoyment already !agree. In addition, the treble glare they're hearing could also be some hardened earwaxes on their ear canal which creates a wheezing, high-pitched sound.
But come to think of it, no wonder it always sounds better once I clean my ear. Clean ear makes sound clear. Hard to put in words. Now its like am bullshitting.
im just kidding.Is it ? I never knew about this, is there any science and evidence regarding your supported statement ? This is the first time am hearing. But this kind of statement and discussion going out of the topic of audio and music enjoyment already !
By the way, am not kidding about the ear wax and perception of hearing sound.im just kidding.
ah ic. hehe. maybe, it could be. That's the reason why I'm a headphonr guy and not an iem guy because my ears creates too much wax that I find it gross. Just the thought of it makes me puke.By the way, am not kidding about the ear wax and perception of hearing sound.
Yes same here. Bt am not an IEM guy not because of ear wax. To me headphone>speakers as well. Though I admit speakers sound better. I just dont have the space and money to invest. HPA-4 would be awesome even for IEM and Speakers as they have pre amp.ah ic. hehe. maybe, it could be. That's the reason why I'm a headphonr guy and not an iem guy because my ears creates too much wax that I find it gross. Just the thought of it makes me puke.
Total: 8 (members: 0, guests: 8)
