cansman
- May 5, 2004
Hi Elias,
Thanks so much for testing the Mac OS X! It's really good to know that I can divert system sounds away from the DAC1 - it gets annoying with the system sounds occasionally breaking through!
Based on your testing, is bit-transparency 44/24 achieved regardless of volume settings of the Built-in Audio (input and output)? This helps in being able to independently set system sounds to a reasonable level without it being too loud through the computer speakers.
Related to the above and as my previous post, if the above is true, I presume the alert volume setting under system preferences>sound>sound effects can be set at whatever level and the choice to engage or disengage the "play user interface sound effects" and "play feedback when volume is changed" settings does not affect bit-transparency?
Finally, thanks for discovering this - it is really baffling that iTunes is not bit-perfect at other sampling rates other than 44/24! Fortunately for me, most of my music is encoded with apple lossless.
Thanks once again Elias for being so helpful.
Warm regards,
cansman
Originally Posted by EliasGwinn /img/forum/go_quote.gif Cansman, I got a chance to put the MacBook on the bench. It seems to be bit-transparent independent of what 'System Output' is set to. Also, I noticed that iTunes was able to achieve bit-transparency at 44/24, which is new to this version (7.3.1). It is still NOT bit-transparent at 24-bits with other sample-rates. (I don't have any idea why it would be like this, but ![]() Thanks, Elias |
Hi Elias,
Warm regards,
cansman
