Well, I've had my DAC-1 PRE for a few months now and have slowly been wading through this thread. I'm finally finished. I feel like I've just earned my undergrad in DAC-1.
I bought it before I found this thread, and once I saw this I thought it would be worthwhile to read through. Little did I know at the time that I had stumbled upon one of the most informative and interesting threads in all of the internets. What Elias has done here is real testament to the customer service of Banchmark and his presence and dedication has really served to reinforce my satisfaction with the DAC-1 purchase.
I'm using it with some Dynaudio BM5A's, an HSU sub and headphones (AKG K701, K270 Playback, Grado SR60, Shure E4G). The transparency of the DAC-1 is awesome. I've had some other decent quality DAC's in this system, the Neko D100, the Music Hall 25.2 and an Essence STX. There were things I liked about all of them, but prefer the DAC-1 PRE to the others by a good margin. It's really an awesome piece of equipment.
After having gone through here, I do have a few questions I was hoping Elias could address.
The first is in regards to J. River Media Centre. Fairly early on in this thread some people had asked if you had ever done any testing with it, and you hadn't at the time, and there is still nothing in the Benchmark Wiki with regard to it. I was just wondering if you ever had a chance to play with it and if there were any settings that you could recommend for bit-perfect playback. I only use J. River with FLAC files and just want to make sure that I am getting the best possible quality from the pc side.
I know for other programs that you've recommended using a 24-bit word length so that if digital volume control is used or the bits are otherwise somehow altered that the 24-bit word won't be truncated to 16-bits. In J. River, you can choose 16-bit, 24-bit, or use the native word length of the file. I have all volume controls set to 100%, so I have been using the native word length. J. River seems to recommend setting it to 16-bit, which doesn't seem like a great idea to me, so this is why I'm wondering if you have tested it, to see if there is a preferred setting.
The second is just a general question with regard to Windows 7 audio. I know you did testing with XP, but didn't see much information with regards to Vista and Windows 7 audio. Have you done much testing with these OS's? I believe I read somewhere in the thread that there was no way to bypass SRC in Vista/7 unless using asio/kernel streaming, so even if playing a 16/44.1 file and having the sounds in the control panel set to 24/44.1, Windows will still resample, but the sample rate conversion is of such high quality that it won't degrade the audio. Is this correct? Or is there a way to bypass the Windows SRC with the proper settings?
I've tried WASAPI, but occasionally when I do other things while listening the audio will get buggy, skip and not sound right. I can't say I noticed a difference in sound quality whether using kernel streaming or not, so my settings right now in J. River are to playback at the source sample rate and bit-depth, all volume set to 100%, with sounds in the OS set to 24/44.1. I'm extremely happy with the sound from the Benchmark DAC-1 PRE as it stands, but would really appreciate knowing if you think there is anything I could do to improve these settings.
Thanks.
