Scrith
Here is a link to a very interesting question-and-answer round with several computer-based audio experts on the state of current computer audio technology.
Some of the most interesting answers were from Charles Hansen of Ayre Acoustics. Ayre is going to be releasing a new USB DAC in March that uses the asynchronous approach to USB audio (as I told Elias about several months ago). Here are Mr. Hansen's thoughts on a question about USB and other computer interfaces to DACs:
Any thoughts on those comments, Elias?
USB - There are a ton of USB DACs out there that suck. The problem is that Burr-Brown released a bunch of cheap chips that had both a DAC and USB support. (Some also have a digital out, as used in the Wadia dock.) They are super easy to use and require no programming. But they have two problems. The first is that they are limited to a max resolution of 48/16. The second is that the jitter performance is HORRIBLE. We are talking literally 100x worse than a good one-box CD player. There is another chip from Burr-Brown called the TAS1020B. It is programmable, but it is super hard to do so. Only two people have done it in audio to my knowledge. There is a third- party developer called Centrance that has written code for the device that allows it to go up to 96/24. This is used by some pro companies like Benchmark and Lavry. Some high end companies like PS Audio and Bel Canto also use it. But they have done nothing to address the HORRIBLE jitter performance. About the only good thing about this approach is that the DAC is not built in. Therefore, many of these guys use jitter reduction devices, typically a sample-rate converter (SRC), before the DAC chip. But the best way to do USB is what is called "asynchronous" mode. This means that the master audio clock is in the DAC box instead of the computer. This is the only way to get jitter performance as low as a good one-box player. Gordon Rankin of Wavelength wrote the code for the TAS1020B to do this, and we are licensing it from him. dCS also has some new add-on boxes for their big stacks of boxes that uses "asynchronous" mode. Everything else is seriously flawed by comparison. Using an SRC chip to reduce jitter is somewhat controversial from a sonic standpoint. (They tend to measure well enough.) Basically, what they do is throw away all of the original data and calculate new data that is their best guess as to what the data would have been if there hadn't been any jitter. The "best guess" refers to the algorithm used. The latest ones measure extremely well, but still haven't convinced everyone from a sonic standpoint. |
