Lord Chaos
- Jan 31, 2007
Thank you, Elias. That corroborates my experience, but I was curious.
Originally Posted by EliasGwinn /img/forum/go_quote.gif First of all, we do not suggest removing the headphone-mute-function. Where did you hear that? |
Originally Posted by joijwall /img/forum/go_quote.gif Page 13 Rev D of the Manual: "TIP: If the DAC1 USB is being used in a critical signal chain" |
Originally Posted by Wavelength /img/forum/go_quote.gif Here are some of the things that I would consider variables for errors on the USB link: |
Originally Posted by Wavelength /img/forum/go_quote.gif The good thing is this... you follow these rules and really you may never have a problem. |
Originally Posted by Ross MacGregor /img/forum/go_quote.gif Gordon, Thank you for the wealth of information on the subject. This is exactly what I was looking for. It's great to hear from someone who has actually tested the hardware under real operating conditions. Great USB tips for DAC owners, this should be on a Web page or stickied somewhere more permanent. I might have used my front panel USB ports without thinking they would be more prone to error. |
Originally Posted by joijwall /img/forum/go_quote.gif Page 13 Rev D of the Manual: "TIP: If the DAC1 USB is being used in a critical signal chain (...) the headphone mute switch should be defeated using the internal jumpers." |
Originally Posted by infinitesymphony /img/forum/go_quote.gif But more importantly, the DAC1 does not accept multi-channel signals because it's a two-channel DAC. You'll have to decode the DTS stream in software, then downmix it to 2.0 stereo, and by that point, it won't be bit-perfect. |
Originally Posted by eweitzman /img/forum/go_quote.gif Or use three DAC1s ![]() - Eric |
