I have recently taken delivery of an iBasso P4 "Warbler". I am using it with the stock op-amp configuration, and with gain set to "low" (to drive GR07 IEMs). Whilst it sounds excellent (particularly in terms of soundstage and dynamics), the battery performance has been less than stellar! In particular, if the unit is left switched off for a few days, the battery goes completely flat.
Has anyone else experienced this with iBasso equipment?
Is this normal (i.e. a bug or "feature"), could it be user error (should I leave the "charge" switch on the back in the "off" or "on" position when it is not being charged?), or is my unit likely to be faulty? If it is a faulty unit, could this be rectified by simply replacing the rechargeable battery, or will I have to send it back to iBasso?
Thanks!
Thanks!
