Battery powered Gilmore Lite/V1?
Oct 19, 2004 at 2:34 AM Thread Starter Post #1 of 7
null
Just a quick question. What type of batteries do I need in order to run a Gilmore Lite or V1? (I plan on building one, but not the PSU) will two 9V be good?
Oct 19, 2004 at 10:03 AM Post #2 of 7
a gilmore needs at least +/-12V and consumes more than 200mA by rail. Batteries are just unpractical for a class A amp. On the other hand, with 3 car batteries, you could try
if you really don't want to build a PS, you can buy the elpac wm072
Oct 19, 2004 at 11:36 AM Post #3 of 7
Once upon a time, there was a variant of the Gilmore dynamic amp made for mint tins. It never saw a second board run. The End.
Oct 19, 2004 at 8:12 PM Post #6 of 7
it depends on how you wire the whole thing
If your pcb (what will you be using ?) has pads for it, yes. Otherwise it's just a matter of having a power jack on the enclosure and 3 wires (+,- and gnd) running to the board.
