nick_charles
- Feb 26, 2008
Yes and no. If you look at the tests that Stereophile has done on CD players there is a wide variation in patterns, some have very evenly spread jitter that is essentially low level background noise, others have a few strong sidebands around the fundamental and then at harmonics with decreasing intensity, some have a mix of both. The pattern for the oppo is the worst I have seen.
EAC also does error correction but it is just different, EAC homes in on C1 and C2 errors and can reread sectors multiple times to get a best guess but it is still possible to have errors get through if your disc is mangled enough, they are rarely audible though.
CDP error correction is inferior in that the disc has to be read and rendered in real time, but the instance of uncorrected audible CD errors is pretty low, I do not speculate on how audible the correction process is but I rarely hear audible blips these days.
As for just having the wrong bit value, this would only be an issue if you had a whole string of them one after another and if the errors were predominantly in the high order bits. For instance if the signal is
01000000001111 and the cd player sees 0100000000001110 that is pretty negligible but if it was 0100000000000001 and the CD sees 000000000000001 well that is a big issue but that is 1/44,100 of a second so you would need a lomg stream of these bad values to have an effect ?
How would you know the difference between error correction and just the different sound of different CD players. I do not know of any research that has looked at error correction and listeners ability to detect it but if you have some sources I would be interested to read about it.
I remember that some of the early CD players had little error correction LEDs that flashed to let you know the error correction was working.
Originally Posted by regal /img/forum/go_quote.gif Not only that but in the real world Jitter isn't concentrated at a single frequency it is spread throughout the audio band making it even more impossible to hear. |
A computer harddrive is superior to a CDP because with EAC there is no error correction being done as we play our disks, error correction is audible. |
