chicken beer
- Apr 12, 2015
Wanted to chip in my two cents.
Currently have the Woo Audio WDS-1 Reference DAC -> HD800S -> with a Woo Audio WA22 with a couple hundred dollars in upgrades ($2200 amp)
Tested both balanced and single ended and here is what I have found.
Balanced sounds better, it sounds more spacious more wide more fat.
The level of clarity is about the same but the difference I hear is the soundstage, it sounds like the musician is in the room with me! (listen to Pink Floyd - Wish you were Here)
I am one of those people that vote for balanced, after listening to single ended for most of my life.
I see. How did you do the comparison? Did you use the same cable but an adapter? I think the proper way to do the comparison is to use the same balanced output on your WA22, but use an dual XLR adapter and connect to your HD800s TRS cable, comparing which to use the same quality Sennheiser balanced cable plugging directly into the balanced..
I never tried balanced except using the balanced output in a Hifiman DAP. But my guessing is that balanced transmission circuit design is simple in physics for amp designers to improve the circuit design, therefore facilitating the signal improvement.
