axlt2002
Hello,
I'm going to receive my Shanling M3 Ultra in few days and I would really love to experience its 4.4mm audio output (it should provide a more powerful and clean audio signal) with my Sennheiser Momentum 4 that I currently use with its stereo cable (3.5mm / 2.5mm). So, my first question is: does the use of balanced output worth it with a stereo earphone in terms of audio quality or it could even sound worst? If yes (I hope is a yes!), should I go for a balanced to stereo adapter (i.e., 4.4mm male to 3.5mm female) to which connect the cable I'm actually using OR replace this with a new cable that has a balanced 4.4mm plug on one side and a stereo 2.5mm plug on the other? This way I should have the balanced signal until the earphone, right? In case, it would be great to have also some hints on which cable to buy.
Hope I was clear enough. Looking forward for help and suggestions!
Have a great day!
Alex
Have a great day!
Alex
