Balanced replacement headphone cable
Mar 12, 2007 at 1:33 PM Thread Starter Post #1 of 10
tufflitestudios
I have been looking at replacement cables for my HD650’s. In this situation what would a balanced cable be? Is that when it ends with two xlr’s instead of a mini or 1/4?
Mar 13, 2007 at 4:47 AM Post #4 of 10
Originally Posted by tufflitestudios /img/forum/go_quote.gif
Thanks that's what I thinking. What would be the advantage of this type of connection?
Um . . . that the headphone is balanced.
I have also been looking into getting a balanced cable for my HD650. They are not cheap though. Some of the sponsors sell them: HeadRoom, Moon Audio, Stefan AudioArt, HeadPhile, TTVJ. See the links at the top of the page.
Mar 13, 2007 at 4:54 AM Post #5 of 10
XLR plugs are better in terms of flat out performance due to their superior design, but you will only reap the benefits of balanced sound if you have an:
unbalanced source-->unbalanced to balanced converter (some balanced amplifiers have one inside)-->balanced amplifier
or
balanced source-->balanced amplifier
with all the proper cables, of course.
Mar 13, 2007 at 1:30 PM Post #6 of 10
This is all great info and I am getting closer to understanding. But apparently I don’t know what the difference is between balanced and unbalanced. Is it a type of signal or type of interconnect? Help me out here let’s start at the beginning.
Mar 13, 2007 at 1:47 PM Post #7 of 10
to get the most from balanced you need different interconnects and equipment
balanced cables means there's about twice as much power going to the headphone
balanced configurations mean that each channel has its own ground
fully balanced configs usually mean that there's 2 x as much ampage compared to a single ended equiv - twice as many components, two PSUs etc.
balanced cables benefit from common mode noise rejection so aren't affected by outside noise/interferance as much
balanced however required expensive accompanying gear and recabling
some details here: http://bluejeanscable.com/articles/balanced.htm
Mar 14, 2007 at 2:09 AM Post #9 of 10
Balanced is a type of signal that requires appropriate components and interconnects. If you're looking for a simple balanced solution, a Headroom amp with a DAC inside would be a good option.
