amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
No. The monoblock concept has other merits beyond separate power cords (in fact I don't consider the separate power cords a big advantage per se, it's just a "given" since true monoblocks are in a separate chassis per channel). Also, monoblock design make more sense for high power speaker amps rather than headphone amps due to the large currents involved.
Some of the benefits of monoblock that I consider useful:
- Allow placement of power amp close to the speaker, minimizing the length of the speaker cables and their resistive and reactive effects. This of course assumes a preamp with very low output impedance, and could drive a long, more capacitive interconnect cable without ill effects (unbuffered passive preamps need not apply here). Such placement usually also means that the power amps are located far away from the preamp and sources, so the large power transformers will have little chance of inducing hum/noise into the small-signal circuitry.
- Each monoblock amp has a separate power supply and ground which are not shared anywhere except at the input common ground (through the interconnect cable, where there is miniscule current). Allows for maximum channel separation. Of course a dual-mono construction in a single chassis could be made to do this, but chassis grounding needs to be common in the latter case.
Originally Posted by johnwmclean /img/forum/go_quote.gif I take it on those grounds, you’ve ditched the concept of monoblock design? Just curious... |
