Balanced Dac Questions
Jul 5, 2009 at 8:49 PM Post #16 of 17
Originally Posted by KingStyles /img/forum/go_quote.gif
Im sure its a great sounding dac. The only point I was trying to make is for 1500, you need two of everything in that design. Would a 1500 single ended dac sound better because it allows the manufacture to use higher quality of parts or use a better power supply for the cost? If you just took half of the audio dac so it was just single ended and used the leftover 600-700 dollars for upgraded parts and a better power supply, I think the single ended version of it would sound better than the balanced. Thats why I feel it isnt worth going balanced untill you get up higher in price where balanced will start to top single ended.
I hear what you're saying but you cut this thing in half and it still has tremendous power supply/cleaning with 4 chips and DSP. The $2000 Bryston DAC is a 2 chip DAC. Not that more chips equals better sound necessarily but......just check the internals and see.
I run my SE for the moment.
